Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mercedes Benz
C280
Steering
Rack and Pinion
Replace/Remove
Rack and pinion
2006 MERCEDES BENZ C280
95,000 MILES • 3.0L • 6 CYL • AWD • AUTOMATIC
DLEVELY
MEMBER
1 POST
Replacing rack and pinion. How to remove old and how to flush and fill new unit?
Jul 9, 2017 at 7:21 AM
Experienced Mechanic
I start by flushing the system first. This will get all of the old fluid out so you don't contaminate the new rack.
https://www.2carpros.com/articles/power-steering-fluid-flush
You will need to jack the car up
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Make sure you use a line wrench
https://youtu.be/HNlvgp_YfQ0
and to undo the tie rod ends
https://www.2carpros.com/articles/tie-rod-end-replacement
Diagrams on how to do the job are below. You will need an alignment when done.
Cheers, Ken
Images (Click to enlarge)
Jul 10, 2017 at 8:05 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
