Questions about coolant temp sensor replacement...
HAJDAK872
I'm am going to be replacing the coolant temp sensor in my wifes 2008 Pontiac g5. I'm know that I need to drain the coolant down a bit but I am unsure of how to do this. I have the new sensor and wrench ready, I just need a little help draining the system. How much, and when, should I fill the coolant back up when I'm done?
Feb 2, 2014 at 6:10 AM
EMERGENCYTECH
  • 26 POSTS
There is a drain on bottom of rad. I usually don't drain any make sure engine is cold leave rad cap on slowly remove sensor have new sensor ready once removed quickly screw in new senor by hand once started the tighten with socket. Leaving the rad cap on minimizes coolant loss. Make sure u have a pain under engine.
Plug in new sensor remove rid cap start engine top up coolant let run tell u have good heat make sure coolant leval is full reinstall cap
Feb 2, 2014 at 6:24 AM
HAJDAK872
Do I need any Teflon tape or anything for the threads on the new sensor?
Feb 2, 2014 at 6:26 AM
EMERGENCYTECH
  • 26 POSTS
usualy there is sealant on new part if not then yes i would use some Teflon tape
Feb 2, 2014 at 6:28 AM
