Car alarm indicator came illuminated on the dash
58,700 MILES • 4.6L • V8 • 2WD • AUTOMATIC
NICHOLAS ACCIARDO
  • 5 POSTS
Greetings! Recently the car alarm indicator came illuminated on the dash. The nomenclature indicates that the vehicle should be brought in for service. The car still starts, runs and drives as normal. I would like to clear this notice. I did get two new aftermarket keys cut for the car recently from a locksmith. Any help would be much appreciated!
Jun 25, 2018 at 2:04 PM
  • 55,746 POSTS
The extra keys have created the problem and the car might shut down on you. (I am surprised it is running) Do you have the original keys? Try using them to start the car and then shut it off. Lock and unlock the car using the remote then try to start the car an observe the security light.
Please report back.
Cheers, Ken
Jun 27, 2018 at 6:20 AM
NICHOLAS ACCIARDO
  • 5 POSTS
Ken, apparently the keys that I have are all after market keys. The car was purchased from a dealer via auction and when it arrived those keys were received. One “ilco-B111-PT” key and one “B106” Saturn key. Both start the vehicle, only after I secured the two new fobs did I notice this occurrence.
How should I continue forward?
Jun 27, 2018 at 6:38 AM
  • 55,746 POSTS
You will need to have the new key programmed to the car a shop can do it should cost about $130.00. The Saturn key will not work.
Jun 28, 2018 at 4:30 AM
NICHOLAS ACCIARDO
  • 5 POSTS
Hum, crazy! For the life of me, I do not understand what people would take this gamble!
Jun 28, 2018 at 4:46 AM
  • 55,746 POSTS
You mean get an auction car?
Jun 28, 2018 at 5:15 AM
NICHOLAS ACCIARDO
  • 5 POSTS
Yes. The car is immaculate however, this problem just came up! Drives well with no issues.
Jun 28, 2018 at 5:39 AM
  • 55,746 POSTS
Still sounds like you got a good deal. Just have the key reprogrammed and it should be a good car for you.
Jun 29, 2018 at 5:14 AM
NICHOLAS ACCIARDO
  • 5 POSTS
Will work on that issue. By the way, having the key reprogrammed requires what steps directly? Is there any chance that the key presently will stop working?
Jun 29, 2018 at 8:15 AM
  • 55,746 POSTS
They could Here is the relearn procedure and diagrams on how to change the ignition lock in case you need it
PROGRAMMING THEFT DETERRENT SYSTEM COMPONENTS
PROGRAMMING REPLACEMENT PASSLOCK SENSOR, BCM, OR PCM
IMPORTANT:
The body control module (BCM) must be programmed with the proper RPO configurations before performing learn procedures. See Body Control Module (BCM) Programming/RPO Configuration.
If replacing the BCM with a GM Service Parts Operations (SPO) replacement part, the module will learn Passlock sensor data code immediately. The existing PCM, however, must learn the new fuel continue password when the BCM is replaced.
If replacing a powertrain control module (PCM) with a GM Service Parts Operations (SPO) replacement part, after programming, these modules will learn the incoming fuel continue password immediately upon receipt of a password message. Once a password message is received, and a password is learned, a learn procedure must be performed to change this password again. A PCM which has been previously installed in another vehicle will have learned the other vehicle's fuel continue password and will require a learn procedure after programming to learn the current vehicles password.
CONDITIONS
Use this procedure after replacing:
Passlock Sensor
BCM
PCM
LEARN PROCEDURES
There are 2 available methods to perform the programming procedure:
A 10 minute procedure which requires a Tech 2 and a techline terminal.
A 30 minute procedure which does not require the use of any tools.
10 MINUTE LEARN PROCEDURE
TOOLS REQUIRED
Tech 2
Techline terminal with current Service Programming System (SPS) software
Connect the Tech 2 to the vehicle.
Select "Request Information" under "Service Programming".
Disconnect the Tech 2 from the vehicle and connect it to a techline terminal.
On the techline terminal, select "Theft Module Re-Learn" under "Service Programming".
Disconnect the Tech 2 from the techline terminal and connect it to the vehicle.
Turn ON the ignition, with the engine OFF.
Select "Program ECU" under "Service Programming".
Attempt to start the engine, then release the key to ON, vehicle will not start.
Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF; the vehicle is now ready to relearn the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK.
Turn OFF the ignition, and wait 5 seconds .
Start the engine; the vehicle has now learned the password.
With the Tech 2 scan tool, clear any DTCs.
30 MINUTE LEARN PROCEDURE
Attempt to start the engine, then release the key to ON; the vehicle will not start.
Observe the SECURITY telltale; after approximately 10 minutes the telltale will turn OFF.
Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes ; the vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
IMPORTANT: The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password.
With a scan tool, clear any DTCs, if needed. History DTCs will self clear after 100 ignition cycles.
Cheers, Ken
Jun 30, 2018 at 4:24 AM
