Camshaft position sensor
102,288 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
JASPER JR
  • 8 POSTS
Where would the camshaft position sensor be located on a 2010 HHR?
Feb 16, 2016 at 5:44 AM
JOHNNYT73
  • 924 POSTS
It is an 4 cylinder overhead cam engine, it should be on the side of the cylinder head near near the top. I will attach a photo for you to see. Are you sure you need a cam sensor and not a camshaft actuator?
Feb 16, 2016 at 5:58 AM
JASPER JR
  • 8 POSTS
Actuator would be the one in the back right? Would you think it would be best just to change both?
Feb 16, 2016 at 6:18 AM
JOHNNYT73
  • 924 POSTS
The actuators sit on top of the valve cover I believe on the end. Which part(s) do you need to change? The cam sensor or cam actuator?
Feb 16, 2016 at 6:21 AM
JASPER JR
  • 8 POSTS
The cam sensor on the picture that you attached would the cam sensor be labeled as number 1?
Feb 16, 2016 at 6:26 AM
JASPER JR
  • 8 POSTS
That's what the codes bring up when I had it scanned. My engine light is on.
Feb 16, 2016 at 6:28 AM
JOHNNYT73
  • 924 POSTS
http://youtu.be/tupkLQLT_eM
Feb 16, 2016 at 6:32 AM
JASPER JR
  • 8 POSTS
Thank you, that was very helpful.
Feb 16, 2016 at 7:12 AM
JASPER JR
  • 8 POSTS
Would incorrect oil quality or viscosity cause my engine light to come on? Been getting my oil change at Wal-Mart and it is just the basic oil change.
Feb 17, 2016 at 12:24 AM
JOHNNYT73
  • 924 POSTS
If the code is for the CAMSHAFT ACTUATOR, then yes.
Feb 17, 2016 at 12:27 AM
JASPER JR
  • 8 POSTS
The code or P0014
Feb 17, 2016 at 12:37 AM
JOHNNYT73
  • 924 POSTS
Change the exhaust camshaft actuator solenoid. They fail usually because the screens on them get clogged with varnish.
Feb 17, 2016 at 1:01 AM
JASPER JR
  • 8 POSTS
Okay. Can you send me something that shows how to change that?
Feb 17, 2016 at 1:27 AM
JOHNNYT73
  • 924 POSTS
http://youtu.be/4Dkdd287AKg
Feb 17, 2016 at 1:30 AM
MIGUEL ANGEL SEPúLVEDA
I can’t find it , help me please
Sep 13, 2019 at 2:35 AM
This is a very old post so it would be best to start a new post with your specific information because we have to assume your vehicle is the same as the other person's. That may be true in this case but that is not always the case and it just causes confusion and makes it harder to assist you.
Assuming your vehicle is the same, here are some location diagrams. If you have more questions or can't find it, please start a new post and we will help with whatever you need. Thanks
Sep 13, 2019 at 6:37 AM
