If you are looking for another solution.
Please let me know.
Thank You.
Jul 22, 2021 at 5:29 AM
H. CONIGLIO
MEMBER
I am trying reset the computer ECU.
Jul 22, 2021 at 5:30 AM
H. CONIGLIO
MEMBER
I installed a MAP sensor two weeks ago on my car listed above Ls sedan and still the same codes comes up all the time MAP sensor. was wondering if I have to reset the computer so that code won't come back on again?
Jul 22, 2021 at 5:39 AM
SQM
✓Experienced Mechanic
I have attached the programming and relearning procedures for your vehicle. Please note that you will need a Tech 2 Scan tool to perform the steps.
Images (Click to enlarge)
Jul 22, 2021 at 5:40 AM
SQM
Jus saw your follow up question.
The MAP sensor replacement does not require resetting of the ECU.
Do you remember what was the code number?
Many times that MAP sensor codes come up for other related issues.
I have attached the complete diagnostics for that code, including step by step guide.
This should help you figure out the issue.
Jul 22, 2021 at 5:57 AM
H. CONIGLIO
MEMBER
Or could it be a bad map sensor?
Jul 22, 2021 at 6:07 AM
SQM
Yes, it still could be a bad MAP sensor. We have seen replacement parts not functioning properly out of the box.
Let me know what you find.
Jul 22, 2021 at 6:12 AM
H. CONIGLIO
MEMBER
Does the MAP sensor have a vacuum hose?
Jul 22, 2021 at 7:08 AM
SQM
No, the MAP sensor only have the electrical connector.
Jul 22, 2021 at 7:15 AM
H. CONIGLIO
MEMBER
Would cleaning the mass air flow sensor with cleaner help the MAP sensor?
Jul 22, 2021 at 7:28 AM
SQM
If the MAF has not been cleaned in a while it is a good idea to clean it. But it might not make a difference.
Jul 23, 2021 at 3:51 PM
H. CONIGLIO
MEMBER
I had to take my car listed above ls sedan to the Chevrolet dealership and they found out that is was the body control module was bad causing the check engine light to come on and the MAP sensor code was still good.
