PVC hose or O2 sensor
110,000 MILES
LCHRISTY
It was jumping when idle. It overheated at one point and had a leak with the antifreeze. This is when I took it in the first time. They said that it was the hydro pump and O2 sensor. Fuel injector error was coming up. Hydro pump had a recall so it was paid for. We just paid for the O2 sensor. Then, I got an OBD scan while I was getting the oil changed and 7 showed up - sames as before. It never did seem fixed. He said to wait and call back after two weeks if it was still having issues, but then I had the seizure and was in the hospital and could not really drive it much. Then it started getting worse. That is why I took it back again.
Thank you!
Mar 25, 2019 at 2:51 AM
JOETECHPRO
  • 705 POSTS
Hey LCHRISTY,
It is possible that they did not delete the codes after doing the work the first time.
If you are a returning customer and you have already had a part replaced on their advice they have some responsibility to help you get the issue resolved.
They will need to delete the codes, road test and recheck.
If they do this and can give you a list of fault codes that are still remaining let us know what you have and we can try and give you some advice on what will happen next.
Hope that helps.
Any further questions please do not hesitate to ask.
Regards, Joe
Mar 25, 2019 at 10:26 AM
LCHRISTY
Thank you! I will let you know what I find out today.
Mar 26, 2019 at 2:02 AM
JOETECHPRO
  • 705 POSTS
Hey LCHRISTY,
Any news on the repair/fault codes?
Regards, Joe
Mar 28, 2019 at 5:13 AM
LCHRISTY
Hi again!
The codes are:
U0237
P0106
P0131
P015B
P0171
P0300
P0507
P1101
P2270
Thank you!
Leigh Ann
Apr 5, 2019 at 4:20 AM
JOETECHPRO
  • 705 POSTS
Hey lchristy,
Which engine do you have in your car?
I am not seeing any recalls for the water pump.
What has the dealer done now?
Have they cleared the codes and retested?
Regards, Joe
Apr 5, 2019 at 11:15 AM
