Putting in antifreeze
200,000 MILES • 0.6L • 6 CYL • 2WD • AUTOMATIC
CRYSTAL KRAMME
I cannot find the drain plug and the closes I have found to it is old and plastics. I fear it breaking or not sealing good when 8 put it back in. Can I just drop the lower radiator hose to drain some water out before adding antifreeze?
Nov 6, 2018 at 1:14 PM
CARADIODOC
  • 34,414 POSTS
That is exactly what we do. During the mid to late 1990's, there was a common problem with the sealing surface inside the radiator cracking when the petcock was closed. That resulted in a drip of coolant about once every five seconds. The fix for that was to replace the radiator. Now we rarely use petcocks, partly for fear of that happening again, and partly because the engineers put them where they are hard to get to.
Nov 7, 2018 at 6:40 AM
