Hi, I am planning on installing a Holley ECU to run all the sensors .Truck has a Holley multi port system on it now. When I disconnect the harness from the factory ECU. will the automatic still shift using the speed sensor and the signals from the transmission buffer?
May 24, 2017 at 7:38 AM
