Put key into car in reverse now car is not working?
131,576 MILES • 6.1L • V8 • 2WD • AUTOMATIC
CONFUSEDGUY0881
I drive the car listed above srt8, car was working fine driving to work, until I got into the parking lot and parked. I put my key in reverse in the ignition switch and all the lights are on as usual, I turned the key to start (in some other cars I drive you can’t even insert the key backwards) and then all the electrical stopped and the car is dead? The key fob doesn’t work, no lights to indicate that the car is open or anything.
Sep 7, 2024 at 6:50 AM
  • 55,616 POSTS
Hmm, it seems like the battery when dead or you have a bad connection at the battery cables, here is a guide that can help:
Did the key work backwards before? Please upload videos in your response of any problems so we can see what to help you with.
Sep 7, 2024 at 11:42 AM
