Put in a new motor blower
109 MILES
TREEGA6059
  • 46 POSTS
Put in a new motor blower it work one day and the next day it doesn't work?
Dec 18, 2018 at 5:21 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny,
You might want to check the blower motor resistor. I've attached a picture of its location B4 on the picture and circled it in red. Check to see if the connection isn't frayed/burnt/loose/corroded. Here is a few tutorials for you to view as well:
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Hope this helps and thanks for using 2CarPros.
Danny-
Dec 18, 2018 at 7:00 AM
TREEGA6059
  • 46 POSTS
Thank you. I will work on that.
Dec 18, 2018 at 7:25 AM
TREEGA6059
  • 46 POSTS
I notice the light doesn't come on the air condition dash board but all the others do? Is that a fuse problem?
Dec 19, 2018 at 4:23 AM
DANNY L
  • 5,648 POSTS
Hello again,
Did you check the Instrument panel I/B fuse location? Here is a tutorial for you on how to check:
I've attached a picture of the I/B box and its location. It's a 10 amp fuse. Hope this helps and thanks again for using 2CarPros.
Danny-
Dec 19, 2018 at 5:28 PM
TREEGA6059
  • 46 POSTS
Let me get back in few days on that one.
Dec 20, 2018 at 7:15 AM
TREEGA6059
  • 46 POSTS
I put in a new blower it worked then the next day it didn't. I just put in a new resister. Still doesn't work at all. I notice the air condition light doesn't come on but all the other lights on the board work. I am wondering is this a heating and cold fuse problem? Thank you again.
Dec 20, 2018 at 9:25 AM (Merged)
Good afternoon,
I attached a wiring diagram for you to view. there are three fuses at the top. check those fuses for power on both sides with the key on.
beyond that you will need to go to the blower relay to verify power at the relay itself.
TREEGA6059
  • 46 POSTS
Hi Roy,
Sorry I have not got back to you. I will work in a few days on the car motor blower problem. I received over the holidays a power probel. It looks like it tests fuses and plugs, also it looks like it test the blower itself. I will get back to you when any thing happens. Still need to do a plug digreasing. I had a little difficulty getting into the middle one. I will get it. Thanks a lot.
Jan 5, 2019 at 6:18 AM
