Put car in drive check engine light comes on
160,700 MILES • 2.7L • V6 • 2WD • AUTOMATIC
LEE LUCAS
I'm at a loss here. car was fine for about two years then it developed a skip and a shifting issue where the car would not shift it was stuck in second gear. I fixed the skipping issue and check engine light cleared. now I start the car no check engine light as so as I put the shift selector in drive the light pops on it did not flash just illuminates. I'm lost on what it could be.
Jun 29, 2019 at 3:42 PM
SCGRANTURISMO
  • 4,897 POSTS
Can you pull the Direct Trouble Code (s)(DTC)(s) for us? You will need a code reader to do this. Here is a link for you to go to if you are unfamiliar with how to do this:
Please go through this guide, if needed, and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Jun 30, 2019 at 6:04 AM
