I need a color code wiring diagram for the car listed above for the ignition switch, so I can wire in a aftermarket push to start and stop button.
Aug 16, 2023 at 5:49 PM
✓Experienced Mechanic
Sure, here is the ignition switch wiring diagram so you can see how the system works and how to wire the aftermarket push to start and stop button. This guide will help you test the connections:
