Code p0455, after replacing the purge valve the check engine light is still on?
152,000 MILES • 1.3L • V6 • 2WD • AUTOMATIC
LSANCHEZ31
I just replaced my purge valve and now it clicks (assuming it's working now since it didn't click with the old one) I had the code p0455 so that's why I replaced it. Yet my check engine light is still on. This was the only code I had and I was wondering if I have to use my ob-2 to clear the code for the light to turn off.
Sep 19, 2023 at 10:05 AM
  • 55,721 POSTS
Yes, you do, the code will not clear on its own.
Here is a video to show you how:
https://youtu.be/ahK_eucFi-k?si=C7Ua810j8aE-TO9y
Sep 21, 2023 at 2:56 AM
