Purge valve location
246,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
CARLA REED
  • 27 POSTS
Trying to locate to purge valve. Thanks for your help.
Nov 12, 2018 at 2:29 AM
Good afternoon.
I attached pictures of the valve for you. It is under the hood drivers side.
REMOVAL
1. Remove the battery tray.
Warning
^ The evaporative emissions system contains fuel vapor and condensed fuel vapor. Although not present in large quantities, it still presents the danger of explosion or fire. Disconnect the battery ground cable from the battery to minimize the possibility of an electrical spark occurring, possibly causing a fire or explosion if fuel vapor or liquid fuel are present in the area. Failure to follow these instructions may result in personal injury.
^ Do not smoke or carry lighted tobacco or open flame of any type when working on or near any fuel related component. Highly flammable mixtures are always present and may be ignited. Failure to follow these instructions may result in personal injury.
Caution: Always remove the battery ground cable first and reconnect last when removing both battery cables. Failure to follow these instructions may result in personal injury.
2. Disconnect the tubes.
1 Disconnect the electrical connector.
2 Disconnect the tubes from the evaporative emission (EVAP) canister purge valve.
3. Disconnect the evaporative emission canister purge valve and bracket.
^ Remove the bolt.
4. Remove the evaporative emission canister purge valve.
1 Disconnect the vacuum line from the evaporative emission canister purge valve.
2 Remove the evaporative emission canister purge valve.
INSTALLATION
1. To install, reverse removal procedure.
2. Leak test the evaporative emissions system. See: Evaporative Emissions System > Component Tests and General Diagnostics > EVAP System Leak Test
3. Perform the Evaporative Emission Running Loss Monitor Repair Verification Drive Cycle.
Nov 12, 2018 at 3:34 AM
CARLA REED
  • 27 POSTS
Thank you so much. We are going to give it a shot.
Nov 12, 2018 at 9:13 AM
Sounds like a plan.
You are welcome.
Always glad to help.
Nov 12, 2018 at 8:39 PM
