Purge solenoid
102,000 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
JAYSON360
  • 13 POSTS
I've replaced the purged solenoid 7 times. If I drive the car kinda hard, the solenoid litterally falls apart and that's why I keep replacing it. Its making a clicking sound. I can start the car and it'll run for a few minutes and It starts clicking. It sounds kind of like a sewing machine.
Apr 3, 2016 at 4:19 AM
HMAC300
  • 48,601 POSTS
have it scanned for codes it may be a shorted wire and causing solenoid to wear out. just because a codes says that doesn't mean it's the solenoid, I tmeans it's the circuit that is screwed up
Apr 3, 2016 at 5:39 AM
JAYSON360
  • 13 POSTS
No codes as of right now
Apr 3, 2016 at 6:09 AM
CJ MEDEVAC
  • 11,000 POSTS
DIFFERENT FELLER
IS THAT PUPPY IN A SPOT WHERE IT MIGHT GET MEGA HEAT FROM AN EXHAUST MANIFOLD THAT MIGHT BREAK IT DOWN?
IF SO, COULD SOMETHING LIKE A MODIFIED FOIL PIE PAN BE FASHIONED TO DIVERT HEAT AWAY FROM IT?
JUST A THOUGHT!
THE MEDIC
Apr 3, 2016 at 8:36 AM
JAYSON360
  • 13 POSTS
I'll rig up something and see what happens!
Apr 3, 2016 at 9:45 AM
