Hey there,
I have replaced the windshield washer fluid pump twice on my van; initially the first replacement worked for about 2 months, the old one was corroded to the high heavens and made sense to replace.
Today my new pump is no longer working, no whine or sound can be heard when trying to activate it, so I replaced it with a new pump again. This time nothing changed, and it still isn't working. I swapped the wiring for the front and back pumps to see if this would miraculously fix it as the rear one hasn't worked in 3 years and it did not; however, the rear nozzle suddenly started slowly dribbling fluid out without any button being pressed.
I've disconnected the hose and had it pointing outwards and tried using the front pump and it doesn't spray either, so I am not worried about a clogged line or tip. I just can't seem to find a single schematic or reference to a fuse in relation to the washer fluid pump and am totally lost on this one.
Any help would be great!
TIA,
Greg
TIA,
Greg
Feb 2, 2023 at 2:05 AM
