need a power steering pump?
120,000 MILES • 6 CYL • TURBO • 2WD • AUTOMATIC
MARY LENGYEL
  • 14 POSTS
I have the car listed above GN turbo and need a power steering pump. Having a hard finding one. Do you know where I could look?
Sep 13, 2024 at 3:37 AM
  • 55,677 POSTS
Did you try rockauto or amazon? Here is one for $71.00:
https://amzn.to/4e1wBzm
Here is how to change it out, check out (below). Let us know if you need anything else.
1. Disconnect battery ground cable.
2. Remove steering pump belt, alternator belt and air conditioning compressor belt, if equipped.
3. On all models disconnect steering pump hoses from pump and plug all open lines and fittings to prevent entry of dirt.
4. Remove pump or pump with brackets from engine.
5. Reverse procedure to install.
This guide can help as well:
https://www.2carpros.com/articles/how-to-replace-a-power-steering-pump
Let us know how it goes.
Sep 13, 2024 at 4:05 AM
