Pulling A/C vacuum for first time
200,000 MILES
CHRISTA DICKSON
  • 150 POSTS
Okay, so i'm pretty clear on how to pull a vacuum just connect pump to air compressor. Pretty simple; what i'm unclear on and can't seem to get a simple and clear answer online is the compressor oil. I know there's really no way to know the current oil level and don't want to over fill it either. i have included pictures of everything including the can of pag oil if needed. I don't see a place on this pump for oil so not sure if it will pull any oil . Or do i need to add any oil before or after vacuum? Or just leave oil level as is? A/C in this car is no where near as cold as it should be and gets warm at idle which i was reading to check condenser fan which i plan on doing. i just would like to be clear on oil situation. Any input would be appreciated. thanks
Jul 23, 2020 at 10:53 AM
Here is a guide that goes over this. Step 5 I think answers your questions.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Let us know if you have more questions after reading this and we can go from there. Thanks
Jul 23, 2020 at 11:00 AM
