Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
PT Cruiser
Engine
Symptoms
Stall While Driving
Stalling at higher rpm's
2003 CHRYSLER PT CRUISER
130,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
JOHN1955
MEMBER
1 POST
my car stalls above 2,500 rpm's.
Apr 22, 2018 at 4:04 AM
Experienced Mechanic
Good afternoon.
Several possibilities.
1. low fuel pressure from a failing fuel pump. pressure needs to be checked and verified.
2. clogged catalytic converter. common issue. the catalytic converter gets clogged and does not allow the engine to breathe.
3. timing. you have a timing belt. if it is worn or loose, it will change the timing and not allow it to perform properly.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Jun 23, 2021 at 2:15 AM
Add image or video
Ask a new question
Engine won't start
Engine overheating
