HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chrysler
PT Cruiser
Engine
Symptoms
Stall While Driving
Stalling at higher RPM's
JOHN1955
MEMBER
2003 CHRYSLER PT CRUISER
2.4L
4 CYL
2WD
MANUAL
130,000 MILES
My car stalls above 2,500 rpm's.
Sunday, April 22nd, 2018 AT 11:04 AM
MECHANIC
Good afternoon.
Several possibilities.
1. low fuel pressure from a failing fuel pump. pressure needs to be checked and verified.
2. clogged catalytic converter. common issue. the catalytic converter gets clogged and does not allow the engine to breathe.
3. timing. you have a timing belt. if it is worn or loose, it will change the timing and not allow it to perform properly.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
SPONSORED LINKS
Wednesday, June 23rd, 2021 AT 9:15 AM
Please
login
or
register
to post a reply.
Related Engine Stall While Driving Content
It Will Randomly Cutoff While Driving In Traffic?
Car Stalled Without Warning. Showed Bad Camshaft Position Sensor Replaced Still Showing Bad Camshaft Position Sensor. I Have A 2005 Non-...
Asked by
Anonymous
2007
CHRYSLER PT CRUISER
VIDEO
Is it Safe to Drive Check Engine Light?
Instructional repair video
GUIDE
Engine Stalls While Driving
An engine that stalls while driving and then starts back up again, either immediately or after a short time is different from an engine that just wont start or if the...
2005 Chrysler Pt Cruiser Wants To Die After Idleing...
I Have An Automatic, 2005 Pt Cruiser With 62000 Miles. It Runs Fine While I Am Driving. But After The Engine Is Warm, It Wants To Die Out...
Asked by
Kathy B
2005
CHRYSLER PT CRUISER
Engine Shuts Off When Put Transmission In Drive
Starts In Park And Neutral, Shuts Off When Put In Drive. Runs Fine In Reverse And Other Gears.
Asked by
doris1bob
1 ANSWER
2008
CHRYSLER PT CRUISER
Car Died As I Was Driving
Driving Down The Freeway About 65 Mph, The Car Died. I Still Have Power To Everything. It Cranks To Turn Over But Won't. It Acts Like It's...
Asked by
AudHis
2006
CHRYSLER PT CRUISER
My Car Dies At Every Stop Sign
We Have Replaced The Water Pump And Timing Belt Just Last Week, Before That The List Can Go On And On, But When The Car Comes To A Stop It...
Asked by
credmon765
2004
CHRYSLER PT CRUISER
VIEW MORE
SPONSORED LINKS
How to Read Codes
What to Do When a Check Engine Light?
Code Read Retrieval/Clear Mercedes Benz
Online car repair manuals
