auto gear cannot be engaged?
2005 PROTON SAVVY
91,000 MILES • 4 CYL • FWD • AUTOMATIC
TKSBRAFIQ
I have a Proton Savvy ( Renault Clio ) 2005 year model. When the auto gear is engaged the auto gear transmission lights come on and the auto gear cannot be engaged. At present it only runs on the manual gears.
Jan 9, 2010 at 5:18 PM
SQM
  • CAR REPAIR CONTRIBUTOR
  • 6,383 POSTS
This is actually common issue with these transmission. The Clios (same as the Savvy) manufactured between November of 2005 and May of 2006, that this issue when the gearbox will malfunction and the gear box will switch to the manual mode, without any driver input.
This issue was due to a faulty control module for the transmission.
Renault had a service bulleting out for this issue and they fixed them under warranty.
Not sure if Proton in Malaysia did the same as I do not see any service bulletin from Proton.
https://www.youtube.com/c/2carpros/featured
Sep 23, 2021 at 9:19 PM
