will not start now it is the immobilizer?
76,000 MILES • 1.6L • 4 CYL • TURBO • MANUAL
JOHN SCOTT2
I just bought this car and it will not start now it is the immobilizer. Will not let it start, it just click sometimes turns over. I am a disabled man please help.
Jul 11, 2017 at 7:17 PM
HARRY P
  • 2,292 POSTS
I do not have any access to specific information about your car, but I will try to help you troubleshoot it. To me, that does not sound like something that the immobilizer is doing. it sounds more like either (1) The battery is weak or cable connections are weak or (2) The starter itself is failing.
If you can do it and have the tools, you should start by checking your battery terminals. If you can move the cables where they are connected to the battery, then they are too loose. Simply tighten them up and see if that helps you.
If the cables are tight, find your starter and make sure the cables and bolts on it are very tight. Again, you should not be able to move the cables on that end.
Start with that and let us know what you find.
Jul 11, 2017 at 10:19 PM
TGOMES
  • 9 POSTS
Was this issue ever resolved? I have what sounds like the same problem. Battery and starter are all good.
Feb 28, 2022 at 2:40 AM
SQM
  • 6,383 POSTS
When the immobilizer gets triggered, you will get a blinking car icon with an X over it, on the dash.
Most of the time the immobilizer gets activated due to a bad start control unit (SCU). The SCU is what controls the staring of these vehicles.
Try locking and unlocking the vehicle 5 times with the key fob. Unless there is an internal fault it should reset the antitheft and allow you to start the vehicle.
Keep in mind when the immobilizer gets activated, the vehicle will not crank over.
Please let me know what you have been experiencing or if you have any questions.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Feb 28, 2022 at 3:08 AM
TGOMES
  • 9 POSTS
Is this also for the proton arena 1.5l?
Feb 28, 2022 at 3:46 AM
SQM
  • 6,383 POSTS
All the proton have very similar setup as far as immobilizer is concern.
Feb 28, 2022 at 4:24 AM
TGOMES
  • 9 POSTS
Thank you. Is there any other way of resetting it?
Feb 28, 2022 at 11:51 AM
SQM
  • 6,383 POSTS
Another common way for any vehicle is to disconnect the battery and wait for about ten minutes, then connect it back and try to see it that resets it.
If these methods don't work then it is likely a faulty immobilizer module.
Feb 28, 2022 at 12:32 PM
TGOMES
  • 9 POSTS
Thank you. So, when I try to start it, it turns over only once. Then when I try several times again, only the ignition lights come on, but the engine does not turn over. Only a few hours later when i try again does the engine turn over but only once.
Feb 28, 2022 at 2:15 PM
SQM
  • 6,383 POSTS
Have you tried to jump start it? It almost sounds like a weak battery.
When the battery is low on charge or faulty it will have just enough to crank over maybe once or twice. It can turn on the lights but not have enough power to start.
Feb 28, 2022 at 2:19 PM
TGOMES
  • 9 POSTS
Definitely not the battery. The same thing happens when we try to jump start it. Turns over only once then nothing only with ignition lights on.
Feb 28, 2022 at 2:23 PM
SQM
  • 6,383 POSTS
Can you tell me what else you have tried? Just one crank can be due to a weak starter drive or even a seized pulley.
Also, if it was the immobilizer, you would not get any crank. It would simply not make any noise.
Mar 1, 2022 at 2:41 PM
TGOMES
  • 9 POSTS
When we plug in the reader it says "transponder not communicating".
Mar 1, 2022 at 2:51 PM
SQM
  • 6,383 POSTS
Do you have the flashing security light illuminated on the dash?
Typically, the non-communicative transponder means the module itself is nonfunctional.
Since Proton is not sold in the USA I don't have access to the repair manual of how to access the transponder.
Mar 1, 2022 at 3:01 PM
TGOMES
  • 9 POSTS
No, it's not flashing. We are able to turn it off and on with the remote.
Mar 1, 2022 at 3:10 PM
SQM
  • 6,383 POSTS
You might have to use a scanner that can communicate with the module and see what error codes there might be present within the immobilizer module. This could determine if this will need to be replaced. Now if you are not able to communicate with the module, even while using a proper scanner it could be a bad module as well.
Mar 3, 2022 at 12:52 PM
TGOMES
  • 9 POSTS
Good morning. the scanner says Transponder not communicating.
Mar 3, 2022 at 2:28 PM
SQM
  • 6,383 POSTS
Generally speaking, when there is no communication to the transponder it is either not getting power due to a bad wiring issue or the transponder itself is bad.
So, a good next step would be to check to see if you are getting power to the module. It should have 12V to the module.
As I mentioned before, since Proton is not sold in the USA, unfortunately I do not have access to the repair manual or diagnostics.
If you have power, then it could be a bad module.
Mar 3, 2022 at 2:49 PM
