Proper temperature range
89,000 MILES • 4.2L • 6 CYL • 4WD • MANUAL
SPITNHIT
  • 23 POSTS
What are your thoughts on temperature rating for a thermostat in my vehicle?
Through Internet research, it seems the 258ci (4.2L) should run between 190-210*. Should I run a 180* thermostat?
Jun 24, 2016 at 8:45 AM
CJ MEDEVAC
  • 11,000 POSTS
The AMC Service Manual says to use a 195 degree stat
I have done that all along (since 1981- 6 CJ-5s) No problems!
I have been doing this for a long time too, look at the end of
https://www.2carpros.com/questions/1989-jeep-other-challlenge-engine-overheating-rapidly-fluctuation-temperature-l/page/2
The 195 gives your heater/ defrost more heat, I have the OEM heater and my own "Sahara Breeze" (uses cooling system water too), two heaters are better than one and temperature is important!)
The Medic
Jun 24, 2016 at 9:30 AM
