propeller noise and steering wheel shakes
131,556 MILES
OZZYMART1
whenever i drive the car going 30mph the steering wheel being to shake and the car itself begins to make a propeller sound im not sure if it is the wheel bearings or a belt issue im not great with cars but i do need some assistance on what it might be exactly
Sep 10, 2013 at 5:39 AM
  • 110,248 POSTS
Check tires to make sure they are not worn unevenly. As far as a wheel bearing, does the sound change with speed? Does the sound change when making turns? Are you sure the tires are properly balanced? Could you have a bent rim?
Sep 10, 2013 at 11:33 AM
