Programming new throttle body
170,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
JOHN BALTHROP
I was just wondering how to program a new throttle body on the Dodge Grand Caravan listed above.
Jul 20, 2020 at 8:40 AM
  • 110,248 POSTS
The relearn process requires a scan tool that can communicate with the electronic throttle control unit. From the scan tool, one would select ETC, relearn, and then enter.
I wish I had an easier answer, but that is right from the manual. The same procedure is applicable when replacing the accelerator pedal position sensor.
Jul 20, 2020 at 8:49 AM
  • 55,649 POSTS
This new scanner can do everything you need:
https://youtu.be/InIlnsjOVFA
Jul 21, 2020 at 4:41 AM
