Programming key
1999 FORD F-150
2,489,565 MILES
MAURICE WILLIAMS
I just changed my ignition key because I had a problem with it. it does have the transponder in it. I'm stuck on the highway I need to know how to reprogram the key so I can start the truck.
Feb 21, 2019 at 8:21 AM
JIS001
  • 3,412 POSTS
Unfortunately you would need an advance scan tool and login to Ford to be able to program the key code. There are a few locksmith that are authorized to program the key or you will need to tow your vehicle to your closest Ford dealer to have it program.
Feb 21, 2019 at 2:43 PM
