Programming after new battery installed
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROBBIEK123
I am currently purchasing the used SUV listed above from an individual. They have had to have the car reprogrammed in reeked once before due to they battery going dead. The car has a new battery and have been re-keyed and reprogrammed. In the future to keep from having to re-key and reprogram it again, someone has recommended an external hard-drive to backup the memory. I've told that this has to be plugged up underneath the steering wheel. My question is, can I use any external hard drive or is there one that is specially made for this problem with Ford Explorers?
May 8, 2020 at 3:49 AM
Good afternoon,
No, there is nothing like that available at all. You would be storing the old program and if it lost its password, that would not do anything.
the best way to prevent it from happening is to keep a truckle charger with the car and when you let it sit for long periods, keep the battery active or fully charged.
If you replace the battery or have to disconnect it, you should hook the cables to trickle charger while the replacement is being performed.
May 8, 2020 at 4:20 AM
ROBBIEK123
Have you ever heard of this happening with particularly Explorers? I had the same exact model for numerous years and never had to reprogram or re-key when replacing the battery. However, I have heard of the Explorer having this issue.
May 8, 2020 at 5:56 AM
This can happen to any Ford model and is common. With the battery disconnected, the password is forgotten and requires either a locksmith or a special scan tool for the programming.
May 8, 2020 at 6:40 AM
