Programming
190,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
CRISANTO BAUTISTA
Hello to everybody,
First of all, i'm Cris Bautista from Barcelona,Spain.I need somebody to advice me about the issue of (security wait time)of my zafira A Y20dth with psg16 pump. I have just finish replacing it.but what have had happened is,I accidentally programmed with the original pin #,because according to the dealer it was already virgin so i reprogram it by the original carpass of my car but when my tech2 ask the security pin code,i entered it's old pin#so(wrong immo pin code,programming failed)has appeared.then i attempted again for the second time but the (security wait time)appeared.I been waiting for 3 days hopping to disappear but it's seem's nothing happen.still 40:0.then i'd try again with my op-com and the immo have luckily recognized the ECU (immo successfully programmed) but when i attempt to program transponder,i put the same old pin but appeared(wrong transponder entered) now i don't really understand which of them is bad,the immobilizer,transponder,ecu or pin #?.Hopping for your correct and brilliant advice.Thank you and more power.
Aug 2, 2019 at 8:15 AM
CRISANTO BAUTISTA
Hello again to my resource persons.
Tomorrow i will do again your other advice's which i read here.most of this advises here,already i did it,but nothing happened.so i will do it again the remaining.i am not enough good in modern electronic specially computers.my time lineage are late 1970's. it's pretty different those things compare to now.
Thank's again folks
Aug 2, 2019 at 9:27 AM
  • 110,248 POSTS
Welcome to 2CarPros.
I hate to say it, but that vehicle isn't offered in the US, so my technical information is extremely limited. However, let us know what happens and if it works. I will try to help.
joe
Aug 3, 2019 at 2:18 PM
