Programming transponder keys
260,000 MILES • 4.6L • V8
GWADDA
Is there a way to program our two new transponder keys with out a scanner?
Jun 5, 2020 at 2:20 PM
  • 110,246 POSTS
Here is a portion of what my manual indicates:
2005 Ford Truck F 150 2WD Pickup V8-4.6L SOHC VIN W
Using Two Programmed Keys
Vehicle Accessories and Optional Equipment Anti-theft and Alarm Systems Testing and Inspection Programming and Relearning Key Programming Using Two Programmed Keys Using Two Programmed Keys
Using two programmed keys
Key programming using two programmed keys
Note:
- This procedure only works if two or more programmed ignition keys are available and it is desired to program additional key(s). If two keys are not available, refer to Key Programming Using Diagnostic Equipment.
___________________________________
Do you have two programmed keys?
Jun 5, 2020 at 2:44 PM
GWADDA
No, I don't have two original keys just the new un-programmed keys.
Jun 5, 2020 at 3:22 PM
  • 110,246 POSTS
I had a feeling. I hate to say it, but it will require scan tool programming. I wish I had a better answer.
Jun 5, 2020 at 3:30 PM
