Particle filter light turns on and vehicle goes into limp mode?
150,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • MANUAL
XETOXI
Hi, i have the vehicle listed above TDI, i started having problems when going in a high RPM. It gives me the particle filter light and enters limp mode. i have tried to use a solution i bought and poured it into the gas tank. It did not work one mechanic took a look at it and told me to replace the turbo. I did that for nothing because it didn't solve anything.
Please help me.
lol
Jul 4, 2023 at 3:27 AM
  • 55,721 POSTS
The fact that the particle filter light comes on is trying to tell you the filter needs to be changed out due to water or debris in the filter. I would change out the filter to see what happens.
Jul 4, 2023 at 6:10 AM
