Problems starting
30,000 MILES • 1.3L • AUTOMATIC
PAULA WALKER SINCLAIR KING
Last few days I have had problems with car starting hot or cold start is the same. I turn the key and when the dash lights up the car symbol either stays and the car starts fine or it goes out and the car will not start. Nothing sounds different so I wonder if it the immobilizer playing up?
Jun 18, 2018 at 2:22 AM
KHLOW2008
  • 41,812 POSTS
Hi Paula,
I believe you are correct about the immobilizer acting up. When the control system could not read the transponder it would not allow you to start and that is where you see the security signal staying on or going off. A scan tool should be able to let you know if any error codes had been stored.
I am not sure if scan tools provided by parts stores have this feature but you can give it a try.
Jun 20, 2018 at 1:24 AM
