PROBLEMS AFTER NEW FUEL PUMPS INSTALLED/GAS CAP ICON ON DASH
150,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
HOOKIE
  • 95 POSTS
Do u know why my gas cap light displays on dash then shuts of and throws a CODE (CHECK ENGINE LIGHT) I intsalled a brand new cap still doing same thing
Aug 3, 2025 at 12:07 PM
  • 55,694 POSTS
Yes, this means there is a leak in the EVAP system. Usually it will be the vacuum line or the canister is leaking itself. You can use a smoke machine to help find it. Please go over this video to see what I am talking about, the machine has an adapter to fit onto the gas fill tube.
https://www.youtube.com/watch?v=LRKWV4Are5c&t
I have also seen the O ring at the 90 degree elbow leak, here is the location of both so you can check it out. Check out the images (below). Please let us know what happens.
Aug 4, 2025 at 6:35 AM
