problem with gas line
195,640 MILES • 2.0L • 4 CYL • FWD • MANUAL
ANTHONY BARRON
  • 8 POSTS
Fuel wont go from back to front,fuel pump is working ,car turns over but wont start,disconnected gas hole ,no gas coming out once fuel pumps on
Jan 17, 2016 at 2:36 AM
WRENCHTECH
  • 20,760 POSTS
If nthe pump is running and no fuel coming out of the line, you either have a bad fuel pump or it's just out of gas.
Make sure you're checking the right line.
Jan 17, 2016 at 2:54 AM
ANTHONY BARRON
  • 8 POSTS
Ok thankyou going to check now
Jan 17, 2016 at 3:08 AM
  • 31,937 POSTS
Pick up not blocked?
Jan 23, 2016 at 12:02 PM
WRENCHTECH
  • 20,760 POSTS
There's not reason to suspect that but it would be obvious during the pump change.
Jan 23, 2016 at 8:58 PM
