Problem with engine after I put 02 censors on.
193 MILES
CADDY MAN
I put 02 censors on and ran the car ten miles and came back home . And on my gas gage all lines were gone n didn't run out of gas but turned off car and started it again just to make sure the car was ok and not out of gas! I didn't start it for 2 days n now she won't start I put 2 gallons of gas in and it won't start I put fuel injector stp in it with the gas and she still won't start she turns over n wants to start I even put fuel in the motor and it starts but won't stay running please help me I really love this car I've done a lot of work to it and hate to get rid of it
Sep 30, 2013 at 12:09 PM
HMAC300
  • 48,601 POSTS
check fuel pressure at rail and if pump isn't working check to see if relay is good. should be 41-47 psi with key on engine off
Oct 1, 2013 at 1:51 AM
CADDY MAN
Thank you it was my fuel pump . And also I wanted to ask my Cadillac is its fuel rich how can I fix that problem? Thanks
Oct 4, 2013 at 7:53 AM
HMAC300
  • 48,601 POSTS
check the fuel pressure it may be the regulator also scan for codes.
Oct 4, 2013 at 9:02 AM
