Problem with car starting
100,000 MILES • 2WD • MANUAL
NIK ORVIS
Hi. recently my car has not been turning on first turn of the ignition. I generally have to turn the ignition, turn it back off and take the key out, then turn again and the car starts fine. When first trying to turn the key, the engine seems to just tick over without starting. Once it has started on second turn of the key it drives completely fine, but when the car has stopped and cooled down for around ten minutes the problem happens again when trying to turn the car on. I have tried to have this fixed a couple of times by mechanic, but does not seem to be able to fix it. Do i need to see someone other than a mechanic to get this fixed?
Sep 1, 2016 at 3:55 PM
HMAC300
  • 48,601 POSTS
check battery for condition including load test most places do for free and make sure terminal ends are clean then try resetting security system if no owners manual look online for your car on how to do it.
Sep 1, 2016 at 11:13 PM
RENEE L
  • 1,260 POSTS
Hi NIK,
If you decide to check the condition of your battery yourself here is a link to an article form this site that features written instructions, pictures and a video explaining how to load test your battery yourself. If you need further assistance please come back to 2CarPros.com. We are always happy to help.
https://www.2carpros.com/articles/how-to-check-a-car-battery
Thank you for visiting 2CarPros.
Kindest regards,
Renee
Admin
Sep 2, 2016 at 4:12 AM
