Problem with a car
100,000 MILES • 1.9L • TURBO • 2WD • MANUAL
MARCIN ZUKIEL
Hi.can is slowing themselves.and switching off my engine.on wet surface .it may be abs?.thanks
Dec 28, 2015 at 3:53 AM
abs will not shut off your car
do you have any codes in the system??
Dec 29, 2015 at 4:51 AM
MARCIN ZUKIEL
Hi.after that problem.i've connected a vag to check problem.they found me one with engine something like a/c and 2 problem in abs brakes.thats really word. I feldspar like my car slowing down by engine. Stopped.my car.after that I couldn't start engine
I had to connect vag to unblock.on dashboard showed me oil pressure off something like that
Dec 29, 2015 at 6:08 AM
CJ MEDEVAC
  • 11,000 POSTS
DIFFERENT GUY,
MAYBE ROY COULD HELP YOU BETTER IF YOU WOULD POST THE ACTUAL CODE NUMBERS (NOT THEIR MEANING)
THE MEDIC
Dec 29, 2015 at 7:35 AM
MARCIN ZUKIEL
Hi.i don't remember a fault codes. But one was i option engine - air compressor. A 2 was in ABS brakes .I erase them is ok. but on the road they may back.thats really dangerous on the road
Dec 29, 2015 at 7:57 AM
thanks CJ.
please have the codes read again and give the numbers so we can further help you. there are over 1500 codes. thats why we need the actual codes
Jan 3, 2016 at 2:49 AM
