Problem starting up
239,792 MILES • 2.0L • 4 CYL • 4WD • AUTOMATIC
ELIZABETH CASTILLO
After I drive my car, when I get to my house and turn off the car, it will not start again. I must wait for twenty minutes or so then it will start again.
Apr 6, 2017 at 3:05 PM
HMAC300
  • 48,601 POSTS
does it turn over? if it does not check fuel pressure with a gauge. auto parts rent it and you may need an adapter. a lot of times it is low fuel pressure causing this. See link.
Apr 6, 2017 at 11:59 PM
ELIZABETH CASTILLO
Yes it turns over. It is almost like I have to wait for it to cool down for it to start again. After about fifteen or twenty minutes it starts right up.
Apr 7, 2017 at 2:13 AM
HMAC300
  • 48,601 POSTS
do what I suggested in first reply a bad fuel pump does what you are talking about.
Apr 7, 2017 at 2:30 AM
