Will not start, smells of fuel really bad, also throwing a p0336?
180,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
EARL91
  • 88 POSTS
I just put a new crate motor in a 2000 Chevy Tahoe. 350 5.7l. won't start smells of fuel really bad. And a bad crank shaft positioning sensor. I can replace that. Why would it smell of fuel so bad?
Jan 21, 2023 at 1:51 AM
  • 55,711 POSTS
How long has the truck been sitting? You may have a tank of bad gas that will need to be flushed out or drained and new fuel put back in it.
Here is a video to help show you how:
https://youtu.be/Q5MH2gnyFH0
and this video will show you how to install a new crankshaft sensor.
https://youtu.be/-Ib3Lkde3Wo
Jan 22, 2023 at 3:26 AM
EARL91
  • 88 POSTS
It is throwing a p0336 and p0339 code. Can't be the reluctor rings they are brand new.
Jan 23, 2023 at 2:15 AM
  • 55,711 POSTS
P0336 Crankshaft Position Sensor A Circuit.
P0339 Crankshaft Position Sensor A Circuit Intermittent.
So these engines have two different reluctor rings 24x or 58x you must have the correct one for the PCM.
Jan 23, 2023 at 4:24 AM
EARL91
  • 88 POSTS
My 2000 Chevy Tahoe. Just put new crate motor in. It's throwing a p0336 and p0339 code. How can I fix. Also need a ground wire pdf. I think that may be the cause. Or to much voltage.
Jan 24, 2023 at 3:05 AM (Merged)
  • 55,711 POSTS
Sure, here are the ground wiring diagrams and locations, did you look into the reluctor wheel? Also check the electrical connector at the sensor.
Jan 24, 2023 at 3:41 AM
EARL91
  • 88 POSTS
I just put a new crate motor in it. I got it to turn over. now it's giving a p1626 code. need detailed description of how to fix it, and a ground diagram for all wires. Please help.
Jan 25, 2023 at 9:07 AM (Merged)
EARL91
  • 88 POSTS
Yes, I looked into the reluctor ring that fixed my no crank. But now it cranks and stalls. Throwing a p1626 code.
Jan 25, 2023 at 10:25 PM
  • 55,711 POSTS
Okay cool, we are getting closer please start a new questions for the p1626 code.
Please post your new question here, you must be logged in.
Cheers, Ken
Jan 26, 2023 at 9:16 AM
