problem starting
200,000 MILES
DEECHA121
The car does not start. I check to make sure that there is fuel and spark. The spark plugs are fine. The compression is 110 psi and there are no check engine light. What else do I need to do? What are some possible cause?
May 17, 2013 at 4:32 PM
HMAC300
  • 48,601 POSTS
check fuel pressure with a gauge if not up to spec replace fuel pump
May 18, 2013 at 1:22 AM
DEECHA121
The fuel gauge is OK. What else is there that I can check?
May 18, 2013 at 2:24 AM
HMAC300
  • 48,601 POSTS
not the fuel gauge you need to check to see how much fuel pressure is going to the engine........
May 18, 2013 at 3:00 AM
