problem of accelerating in the begining
128,000 MILES • 5.7L • V8 • RWD • AUTOMATIC
GULZAR
When ever I start my car accelerating comes down after few seconds it seems car will stop then suddenly after shocking it becomes normal but there is vibration I can feel it in steering.I showed it to Machanic he told me change the plugs I changed then he told me change the plug cable I changed then I told me change air flow cable sensor I changed Than I have been told change the fuel filter I changed then I been told to change fuel pump I changed Then I been told change the battery I changed then I been told change the mas air flow sensor I put this duplicate to see the change but same problem still is there. Can anyone can suggest me what should I do to get rid of this problem because I showed about nine mechanics but no one helped me.I don't know even mechanics do not know the problem of my car.please advice what should I do?
May 27, 2014 at 2:41 AM
HMAC300
  • 48,601 POSTS
vibrations should be checked out by a pro not just someone telling you to change this or that. take a compression check and clean throttle plate on both sides an iac hole with choke cleaner.
May 27, 2014 at 5:22 AM
