Replaced radiator and spark plugs. now it's having trouble codes P0204 P0135 P0837. not wanting to start and if it does it won't run long doesn't want to move when in reverse or drive transmission. trouble codes P1762 and 1763 were present as well. so I changed governor pressure sensor and solenoid and it still throws those codes every now and again. Replaced fuel injectors, fan relay, oil filter, camshaft position sensor, oil pressure sensor, temperature sensor, fan and shroud, water pump and I'm in the process of changing the head gasket now. All these issues happened at the same time, I'm assuming from many years of neglect but I've only had it for almost one year. Any help would be much appreciated.
Jun 11, 2021 at 1:07 PM
