Problem after replacing knock sensors; engine will not stay running
164,000 MILES • 6 CYL • 2WD • AUTOMATIC
DONDUCK
After replacing both knock sensors, all instrument indicators were maxed out.
After turning the key, instruments returned to normal. Then, after turning the key, engine would start and run for about a second and then stall out. Pressing on the gas pedal has no effect.
Sep 20, 2020 at 11:37 PM
4DRTOM
  • 467 POSTS
Your going to have to go through your work and check everything wiring wise. Check that any ground wires were reconnected, any harness plugs are proper and fully clipped into place etc. Something you disconnected isn't connected properly for this to have happened.
This guide can help as well
https://www.2carpros.com/articles/stall-at-idle
We should run the codes as well
Tom.
Sep 21, 2020 at 1:32 AM
DONDUCK
Thank you Tom. I will do that and post what I find and the results if possible.
Sep 21, 2020 at 1:44 AM
