Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Suzuki
Jimny
Engine
Oil
Type
Plugs picks engine oil
2014 SUZUKI JIMNY
50,000 MILES • 0.6L • 3 CYL • TURBO • 4WD • MANUAL
AJMAL13
MEMBER
1 POST
I am facing the problem my car plugs picks engine oil.
I have already change rings of my car engine.
May 21, 2018 at 4:49 PM
Experienced Mechanic
Good morning.
Did you check the cylinder for out of round and taper? You can replace the rings but if the cylinder is not straight then they will not seal.
Did you verify end gaps on the rings prior to installation?
Also, when you installed the rings, did you stagger the gaps so they were not all lined up?
May 21, 2018 at 11:52 PM
Add image or video
Ask a new question
Transmission — Not Shifting
