I am facing the problem my car plugs picks engine oil.
I have already change rings of my car engine.
May 21, 2018 at 4:49 PM
✓Experienced Mechanic
Good morning.
Did you check the cylinder for out of round and taper? You can replace the rings but if the cylinder is not straight then they will not seal.
Did you verify end gaps on the rings prior to installation?
Also, when you installed the rings, did you stagger the gaps so they were not all lined up?
May 21, 2018 at 11:52 PM
