Overheats after mechanic broke coolant bleed screw
160,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
MEGANPITTMAN25
My car overheats ever since I had a mechanic work on it and broke my coolant bleed screw when he was flushing the radiator.
What else could be wrong with it and how can I get this screw out and put the new one in so I can get the air out of the cooling system?
Feb 4, 2019 at 11:09 PM
SEVAG P
  • 405 POSTS
Hello thanks for using 2CarPros.
Here are our guides for engine overheating,run the guide bellow:
https://www.2carpros.com/articles/engine-overheating-or-running-hot
and
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
For the broken bleed screw drill it out, clean the threads then replace with a new one.
Feb 5, 2019 at 4:16 AM
