Previous forum on fuel pump not getting power?
153,000 MILES
JEFFNLEANNA
I read that you answered about the wiring at the relay, specifically the green with white tracer. It should get power while cranking. You said it's the signal wire to the PCM. My question is, why would that wire get power all the time?
Feb 11, 2023 at 12:18 AM
  • 55,808 POSTS
The green/white wire should have power for about 5 seconds when the key is turned on and then hot all the time the engine is running. Here are the wiring diagrams below so you can see how the system works. Let me know if you need anything else.
Feb 11, 2023 at 2:21 AM
JEFFNLEANNA
Okay, thank you. I've got it working but still no fuel coming to the rail. The pump comes on and I get some fuel but not enough to start the car. I had an engine swap with it from a 2001 Cavalier. I had to go through each statement one by one to get all the electrical components to work. Getting fuel to the rail and injectors is my last problem. All my electronics are doing as they should. The fuel filter is almost new as well as the regulator. Any info would be appreciated.
Feb 11, 2023 at 6:13 AM
JEFFNLEANNA
Not each statement I went through each system.
Feb 11, 2023 at 8:30 PM
  • 55,808 POSTS
No problem, it sounds like the fuel pump is weak which is common, but to be sure we can do a fuel pressure test by following this guide and you can rent a fuel pressure gauge from the auto parts store for free or cheap.
Fuel Pressure .................... 53 - 59 psi
KOEO (Key On Engine Off)
Here is a video of the fuel pump job being done:
https://youtu.be/Lhd0vd8pdBU
Please go over these guides and report back.
Feb 12, 2023 at 5:18 AM
