Preventive maintenance
7,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
BOBZANI
  • 13 POSTS
I drive very little, just short trips to stores, doctors., etc. My question concerns whether I should get a new battery and change coolant. Both are 4 years old. I don't want a big "surprise" in the middle of winter. Any help is appreciated.
Oct 27, 2021 at 5:45 AM
SQM
  • 6,383 POSTS
With only 7,000 miles there are not too many maintenances you will have to do.
The battery might be a good idea to change since it is 4 years old. Then again if the battery tested good and holding charge, might not be necessary. If the vehicle sits for extended period of time, it might be a good idea to keep a trickle charger at battery maintenance mode, this way you don't get any surprises on a cold morning.
Unless you have sludge buildup in the coolant, I don't see why you will need to change the coolant at this mileage.
https://www.2carpros.com/articles/symptoms-of-a-bad-car-battery
Oct 27, 2021 at 6:17 AM
