Pressure sensor brake master cylinder adjustment
73,256 MILES • 3.0L • 6 CYL • TURBO • 2WD • AUTOMATIC
JESSE CHILDERS
I’m guessing the pressure sensor on my master brake cylinder needs adjusting. Unsure of what all this “adjustment” entails and if it would be better to have the BMW dealership do the job.
Sep 8, 2020 at 1:25 AM
STEVE W.
  • 15,411 POSTS
What is the issue you are having with the brakes to indicate there is something wrong? The brake pedal travel sensor isn't really adjustable itself, and testing requires the factory scan tool.
Sep 8, 2020 at 1:47 AM
