Pressure build up in a cold radiator
2001 NISSAN
39,500 MILES • 1.3L • FWD • AUTOMATIC
SKYCABS
There seems to be a very high pressure build in my radiator. I noticed this when I opened my radiator cap after parking overnight when the engine is cold. I've also noticed a slight increase in the coolant level in the storage bottle.
Is this normal or not?
Also once I start the engine without the cap replaced i see the coolant fluid gradually rising, over flowing as the engine warms up.
I was asked to replace the radiator cap and check but the problem still exists.
Thanks. Nev
Aug 7, 2014 at 3:23 PM
WRENCHTECH
  • 20,758 POSTS
This is not normal it sounds like you have a bad radiator cap. Here is a video to help you see what you are in for when doing the job.
https://youtu.be/GSE9skKnOgY
Cheers
Aug 7, 2014 at 7:38 PM
SKYCABS
Coz I've noticed my radiator reservoir fluid gradually filling above the max level. Suspect something was not right. I don't want this excess pressure to crack up my radiator. Once I replaced the cap the problem stopped. Thanks for your help
Aug 7, 2014 at 8:01 PM
WRENCHTECH
  • 20,758 POSTS
The system pressure is regulated by the cap and it's supposed to purge some coolant into the reservoir when hot and it will draw it back in when cooled if the system isn't messed with in the meantime.
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers
Aug 7, 2014 at 8:17 PM
