I depressed the bearing use a split bearing puller. Replaced the ignition switch. I cannot get the sleeve and bearing to press enough to get the steering wheel back on. I tried using the steering wheel bolt to tight and press the sleeve and bearing.
Nov 26, 2016 at 3:15 PM
